UDF with VOF method to predict evaporation mass/heat flux at vapor-liquid interface |
March 4, 2022, 04:58 |
#21 |
Rep Power: 4 |
Hello vidyadhar, this macro is assumed that the mass "destroyed" or "created" will have the same energy (from the Theory guide). So I always doubt that a direct use of a correlation between the mass transfer and temperature does not obey the conservation of energy. Simply for an example, the temperature of liquid is higher than that of gas with the same mass and enthalpy.
March 12, 2024, 09:13 |
evaporation udf
#22 | |
Bidax
Rep Power: 2 |
i'm working on this, i wang to know what differents between DEFINE_SOURCE and DEFINE_MASS_TRANSFER ? And i wang to simulation evaporation of a 3d tube,i have some question,would you mind give me some advice? 1.) can i use simulation ? 2.) my iterations tend not to converage thanks in advance! |
March 12, 2024, 09:20 |
evaporation udf
#23 | |
Bidax
Rep Power: 2 |
evaporation, evaporation-interface, hertz–knudsen equation, stefan problem, udf |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
UDF to propagat VOF interface at a specified speed | Johann | FLUENT | 1 | May 27, 2006 12:39 |
interface reconstruction in Fluent VOF method? | daniel | FLUENT | 0 | May 4, 2006 04:46 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
