December 24, 2018, 13:19 |
interaction-mass-linear
a
Rep Power: 13 |
Hi
In the boiling model of a simple 2d geometry, I wanted to insert the saturation temperature of water in different pressures. Now, I was wondering whether it is the absolute pressure or gauge pressure? As the pressure outlet boundary condition is the gauge pressure, I guess I should insert gauge pressure here too. i.e., in the attached photo, the pressure is not written right because it is absolute pressure. So, I should subtract 101325 from this value. Am I right? Thanks Capture2.jpg |
January 2, 2019, 13:52 |
Lucky
Rep Power: 66 |
It's the thermodynamic pressure, which means absolute pressure. Unless there is a bug.
January 3, 2019, 12:23 |
#3 | |
a
Rep Power: 13 |
So, what about the pressure in the pressure outlet boundary condition? Why is it written gauge pressure? In fact, when I see a plot in the results which shows the pressure in the outlet section, I see that it is the same as the pressure inserted in the boundary condition though it was written gauge pressure. |
Steady-State and Transient Solvers | 70m1 | OpenFOAM Running, Solving & CFD | 21 | May 8, 2021 08:09 |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 21:47 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Exit Corrected Mass Flow Rate Mesh Sensitivity Study | s__s__s | CFX | 4 | July 20, 2016 12:46 |
A turbulent test case for rhoCentralFoam | immortality | OpenFOAM Running, Solving & CFD | 13 | April 20, 2014 07:32 |
