How to model two-phase flow along with a single-phase flow within a problem? |
December 9, 2018, 11:26 |
Rep Power: 9 |
Dear All,
I have a Fluent model that has two parts: a part contains two-phase flow and another part with a single-phase flow. How can I model this problem in Fluent? When I try to use different multi-phase models, fluent only give me the option to define different parts flow properties according to multi-phase definition, there is no option to assign a property to the single phase part! Any help would be appreciated! Malekan |
January 2, 2019, 16:55 |
Lucky
Rep Power: 66 |
Within one simulation, your physics have to be consistent in Fluent. If you want to do different multiphase models in different regions, you need to run multiple connected simulations with fancy interfaces.
If you simply want one region to be a single phase, is it enough to use a multiphase model and fix the phase fraction at 1 or 0? Or do you need two different multiphase models? |
fluent 18.2, multi-phase flow |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Two phase flow - velocity problem | andyraq | Fluent Multiphase | 1 | July 17, 2016 06:01 |
How to go about modeling injection nozzle two phase flow in FLUENT? | skonda2 | Fluent Multiphase | 0 | March 17, 2015 08:52 |
lenght and number of nodes for an orifice meter flow problem - k-eps model | fofo | FLUENT | 0 | November 15, 2009 04:49 |
convergence problem of three phase flow | nick | CFX | 3 | April 25, 2008 10:00 |
