Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Wall boiling models comparison
Old   December 5, 2018, 09:49
Default Wall boiling models comparison
Mostafa
mo30raincity is on a distinguished road
Hi
I'm modeling boiling of water inside a tube and I used two wall boiling models, CHF and non equilibrium rpi boiling.
I predicted that when the heat flux is less than critical heat flux, heat transfer coefficient along tube should be the same in both models.
But the heat transfer coefficient that i get from CHF is diffrent from the coefficient that i get from nonequilibrium rpi boiling.
What do you think the reason of this difference is?
mo30raincity is offline   Reply With Quote
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Two-Layer Models and Wall Functions sdwijeya Siemens 0 June 18, 2010 16:25
