Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Droplet deformation in Sudden Contraction pipe
Old   September 28, 2018, 07:43
Default Droplet deformation in Sudden Contraction pipe
wasser is on a distinguished road
I am trying to simulate the deformation of droplet when it is carried by fluid flowing through a sudden contraction pipe.
My setup is as in attachment with very small dimension (in micron).
The diameter of the droplet is 1 micro so I made a very fine mesh to capture the deformation interface (element size is around <0.1 micron).
The problem here is because the small dimension, the velocity is very slow, hence if I took a very small time step (explicit vof), I have to wait forever. But when I used implicit vof, the vf-phase cannot be converged.
Finally, I made some assumptions such as: the droplet should have the same velocity as the carrier fluid at every time step. Therefore, I decided :
1/ Calculating the velocity profile at steady state of the carrier fluid and then
2/ Disable the flow equation (only consider the volume fraction equation) and patching the droplet phase
3/ Conducting the vof without initialization (to use the same velocity profile),
With this method, I can assign a higher time step even with explicit and the droplet moved and deformed.
However other problems appeared, when I try to investigate the effects of viscosity ratio and the surface tension, it seemed these parameters were not considered in the model at all. I meaned I changed the viscosity and surface tension, but the results are the same for every value of them.
Would you please give me some suggestions to solve this problem? Is my assumption ok? Do not consider the flow equation in vof is fine ?
Thank you very much
wasser is offline   Reply With Quote
Old   October 4, 2018, 03:54
Does anyone have suggestions? I got stuck here (
Different results for symmetric flow of pipe sudden expansion FarzinD CFX 30 March 29, 2015 19:01
Simulating liquid droplet deformation mebinitap OpenFOAM 3 June 27, 2013 01:39
Pipe with sudden enlargement kyubi OpenFOAM Running, Solving & CFD 0 January 22, 2008 07:17
Pressure loss due to sudden expansion in pipe flow Ahmed FLUENT 0 January 2, 2006 11:01
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
