August 24, 2018, 12:39 |
Multiphase flow
subhankar das
Rep Power: 8 |
Hi experts
I'm simulating a flow through a open channel. Inlet BC- velocity inlet Top surface - symmetry Outlet- pressure outlet Bottom- wall I'm using VOF multiphase model( air and water) Gravity on, surface tension 0.072, laminar model. I'm plotting volumetric flow rate at outlet with iteration it's showing -0.24m3/s at iteration 1. It means something is flowing through outlet but contour of volume fraction showing water is far away from outlet. It means air is out flowing. How can I stop this? I just want volumetric flow rate when water reaches outlet. |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 01:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 13:15 |
Capillary pressure in multiphase flow in porous media | Lalit | FLUENT | 0 | March 21, 2013 02:24 |
