Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Simulation of Water jacket cooled Heat exchanger for hot oil
Old   August 13, 2018, 20:35
Red face Simulation of Water jacket cooled Heat exchanger for hot oil
Soumitra Vadnerkar
soumitra2102 is on a distinguished road
Can somebody please guide me for a CFD simulation in Ansys Fluent for the following case?
The case is simple with hot pressurized oil running through a steel pipe which itself (the pipe) is submersed in a cooling tank containing water at normal atmospheric conditions .
The hot oil flow in turbulent with temperature above saturation temperature of the outside (cooling) water. The flow at inlet is pressurized and their is no boiling inside the tube.
Thank You.
soumitra2102 is offline   Reply With Quote
boiling, fluent, multiphase
Water evaporation and latent heat simulation buidu Siemens 1 May 31, 2017 11:28
Simulation Water and Oil URGENT problem alexandrelp CFX 3 May 5, 2014 22:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Simulation of Multiphase Heat Exchanger faisal_ahmed92 CFX 6 June 13, 2012 08:33
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
