Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Convergence in multiphase flow(transient) simulation
Old   July 19, 2018, 13:04
Default Convergence in multiphase flow(transient) simulation
Muthu
mari009 is on a distinguished road
Hi all..,
I am running a two phase fluid flow problem(water and air). Initially atm air filled inside the container then Liquid enters container passes through various compartment and leaves the container. I need to solve the case as transient problem ,mesh size – 0.55 million .It takes a lot of time to solve(min 02 days).kindly anybody assist me to solve the case at faster rate.
Model : Vof, Implicit , Realizable, K-Ԑ
Volume of container : 0.000121 m3
Area of inlet : 0.000622 m2
Area of Outlet : 0.00049 m2
mari009 is offline   Reply With Quote
Old   July 30, 2018, 12:21
London
Studentt is on a distinguished road
reduce the detail of the mesh (unless you need the very high detail) and lower the relaxation factors (in setup>solution>controls)
Studentt is offline   Reply With Quote
Old   July 31, 2018, 01:04
Default suggestions
Taiwan,new north city
Rajaero is on a distinguished road
1.what about your mesh quality?
2. which residual is not converging ? (ex, continuity,momentum,energy,vof)
3. if your mesh Skewness is over 0.9 its very hard converge
4. generally, multi phase problem convergence rate is very slow
5. please post your residual image
Thanks...
Rajaero is offline   Reply With Quote
Old   September 25, 2018, 18:36
subhankar das
subhankarnits is on a distinguished road
Hi sir.
I have same problem can you help me?
If you give me your mail I'll send you details of my problem.
subhankarnits is offline   Reply With Quote
Old   October 6, 2018, 19:00
Unhappy
mohammadreza
mohammadrezazakeri is on a distinguished road
hello im doing cfd smulation solar still in fluent later press calculate
im recieve error
Solar Loading model output:
Internally Scattered Energy [W]: 281.802, Ambient Flux [W/m^2]: 65.9987
Boundary ID: 5, Integral Energy Source [W]: 1.656799e+02
Boundary ID: 8, Integral Energy Source [W]: 1.#QNAN0e+00
Boundary ID: 9, Integral Energy Source [W]: 1.#QNAN0e+00
Boundary ID: 12, Integral Energy Source [W]: 1.#QNAN0e+00
Total Integral Energy Source [W]: 1.#QNAN0e+00
Compute Time: 0 sec
radiation resid. = 1.#QOe+00
maximum iterations exceeded in radiation calculations.
please help me
mohammadrezazakeri is offline   Reply With Quote
UDF Parse Error - Initializing VOF for Multiphase Simulation denbjornen Fluent UDF and Scheme Programming 0 April 25, 2018 03:07
Which Multiphase Model Should be selected in Fluent for my below described simulation oberstar Fluent Multiphase 0 September 28, 2017 13:05
Multiphase Simulation - Fluent vinayak4399 Fluent Multiphase 3 December 13, 2015 12:46
Multiphase Simulation of 26ft planning hull lucasiervolino FLUENT 0 September 27, 2015 18:54
how to get a time-accurate solution in Flow Simulation drdet FloEFD, FloWorks & FloTHERM 4 January 20, 2015 08:11
