TL
Rep Power: 0 ![]() |
Hi, I'm trying to simulate 3D flow of water into a 1.6mm diameter tube filled with air. I'm using VOF with PISO, surface tension enabled and set to 0.073N/m, a water inlet velocity of 0.005m/s, a pressure outlet with gauge pressure of 0, wall adhesion enabled and set to 75 degrees, a time step of 0.001s, and the standard laminar flow model.
I've looked at many tutorials and forums and played with just about every parameter I can think of, but cannot get reasonable results. Does anyone have any suggestions? |
Bhargav Bharathan
Rep Power: 11 ![]() |
Can you elaborate on what difficulties you are facing. What results are unreasonable. -BB |
fluent, multiphase, surface tension, tube, wall adhesion |
Pipe flow with obstacle - HELP | Min | FLUENT | 6 | January 31, 2017 14:28 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 16:22 |
simple pipe flow question | arkur | CFX | 1 | July 11, 2008 16:32 |
Pressure Drop - Please Help - Simple Pipe Flow | Joe A. | FLUENT | 2 | April 23, 2007 07:50 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
