May 27, 2018, 16:27 |
Solid liquid flow between annulus
Payam
Rep Power: 9 |
Hello
I want to simulate solid liquid flow inside annulus. Geometry: Di=2 in Do=4 in L=60 in Particle size= 3mm Model: Steady state Eulerian eulerian grannular flow K ebsilon turbulence BC: Inlet velocity Outlet pressure Moving inner pipe 80 rpm Stationary outside wall ________________ ROP (rate of penetration in drilling) = .01 m/s Q_particle= ROP * A_annulus _________________ The single-phase flow is easily solved. When i choose two phase eulerian model i dont know how to calculate volume fraction of solid particles. For example i put volume fraction of solid 0.3 and and velocity inlet for solids 0.01 m/s . Solution didnt converged. Please help me |
Solid Liquid flow volume fraction | Kushal | Fluent Multiphase | 0 | January 13, 2014 05:40 |
flow in a vertical annulus | ramcharan | FLUENT | 6 | December 23, 2010 07:27 |
Extracting fluid flow region from a solid body 3D | Pradeep | Main CFD Forum | 6 | January 29, 2009 12:13 |
flow in annulus | M | FLUENT | 2 | July 16, 2007 10:49 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
