May 14, 2018, 16:37 |
Heated soil drying
Tencho
Rep Power: 12 |
Hello, everyone.
I would like to run a 2D simulation of soil drying with a heat source (see sketch). The initial soil moisture content is relatively low (~20% m/m) and the air is at atmospheric conditions. I would set a constant temperature and relative humidity to make things easier, that is, the evaporated water from the soil would not change the air conditions. I have the characteristics of the soil (e.g. conductivity, average grain size, etc.). I'm thinking of modeling the soil as a porous block with a particular amount of water. I was wondering if this is a reasonable problem and if any of you have done something similar and have tips that could make things easier. Thanks in advance for any help. |
May 21, 2018, 01:40 |
Rep Power: 14 |
There are following options.
a) Treat soil as solid. If no or negligible humidity is released from soil. b) If humidity is released, use DPM and replace the soil with a wall. c) Treat soil as a porous material. all the best. |
evaporation, porous media flow |
soil modeling in ansys ver. 15 | Rana Nasser | Structural Mechanics | 0 | March 18, 2018 10:58 |
Industrial drying - Defining the interface (drying air-porous soil) | Pavel Mihailovski | FLUENT | 0 | February 10, 2018 02:53 |
3 phase setting (erodible soil, water, air) | azril | FLUENT | 0 | July 11, 2017 08:32 |
drying rate simulation for iron ore pellet | wali | Fluent Multiphase | 0 | July 9, 2014 18:08 |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 15:11 |
