giu
Rep Power: 0 ![]() |
Hi everyone,
I am simulating a Spinning Disk Reactor on Fluent. I created a cylinder because I need to value the height of the liquid film once it touches the base of the structure. So I draw: - big cylinder (0,1 cm height and 10 cm diameter); - 2 inlet (cylinders much smaller than the big one) placed on the "superior" face; - the whole body set as fluid body. The bc are these: - 2 inlets: mass-flow-inlet where I set constant flow (kg/s and species in mass fraction); - 2 channels: The heights of inlets (almost 0, created just to let the liquid go in). Stationary walls and no slip; - outlet: the lateral surface of the big cylinder. I need the flow leaving from there for centrifugal force. Pressure-flow-outlet condition; - inferior disc: the "base" of the big cylinder. This rotates, so I set moving wall, rotational on z-axis (with 14 rad/s value of velocity) and no slip. The problem is that during my simulation I get a value of almost 700 m/s for magnitude velocity! It's not possible of course... I have flow values like 10^-3 kg/s (more or less) and that value of 700 m/s has no sense... It's definitely too high! The mixture is composed of 5 components: water and species A, B, C and D. Phases: 1 air and 2 is the mixture. To insert the mixture: I set on inlet 2 the mass fraction of A and Fluent gets water mass fraction (by itself, I set water as last component of mixture) as 1-A. The others are 0. Inlet 1: Mass fraction of B, C, D and Fluent does water = 1 - (B+C+D). model: transient, VOF, Energy equation On, viscous k-epsilon and species equation (but no chemical reaction included). How is it possible???? Another strange thing is when I initialize: z velocity already has an incredible value (almost 400 m/s for every species). I tried also to test the system with just one component (first time A + water, then only B+water and finally C+water) and one inlet (inlet2 set as wall): the system runs same results (slightly lower velocity than 700) for C and D, while for B it diverges on y momentum after few time steps (I set a really small size, 10^-5). The only explanation I have is that B properties of material are wrong, but the speed of other components are absurd anyway... Kind Regards ![]() |
boundaries condition, initialization, rotating disc, rotating disk, velocity magnitude |
HronTurekFsi3 foam-extend3.1 | Maimouna | OpenFOAM Running, Solving & CFD | 112 | April 20, 2019 21:11 |
Magnitude of a tensor | mmkr825 | OpenFOAM Programming & Development | 8 | December 12, 2018 13:49 |
'cell relative: velocity magnitude' vs 'velocity magnitude' | alpharays | Main CFD Forum | 2 | June 18, 2015 07:24 |
Output velocity magnitude | satellite_control | FLOW-3D | 1 | November 30, 2011 19:07 |
Stresseq vs stress magnitude | watashiwa | OpenFOAM | 1 | October 14, 2010 12:02 |
