Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Result with TET mesh is more close to actual physical process than HEX mesh
Old   April 6, 2018, 03:29
Default Result with TET mesh is more close to actual physical process than HEX mesh
prince kumar singh
princeks is on a distinguished road
Actually i am modeling the multiphase flow inside ladle shroud in which water is primary phase whereas air is secondary phase. I am measuring the Liquid free jet length in with HEX and TET mesh. but results with HEX mesh shows much deviation from reality but TET shows good agreement. Number of elements in case of TET mesh is 373k and HEX mesh it is 498k. What should i do??I am attaching the contours of both case.
princeks is offline   Reply With Quote
Too diffusive result on Delaunay type mesh for pipe AlmostSurelyRob OpenFOAM Running, Solving & CFD 7 October 8, 2018 14:34
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[OpenFOAM] ParaView shows bad cells, checkMesh doesn't seem to notice. CoolHand ParaView 2 August 21, 2014 16:58
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
