Divergence detected in AMG Solver: x momentum in Fluent multiphase model |
April 5, 2018, 19:50 |
Adnan Shahariar
Hello everyone,
I am working on a 2D problem of jet impingement cooling. machining. In this problem, water jet is applying on the hot rectangular surface through a nozzle. The temperature of the hot surface is 700 Kelvin. I am using the mixture option in the multiphase model. But when I increase the inlet jet velocity more than 0.5 m/s then divergence occurs in momentum. I have reduced the URF values. But the problem persists. I have tried mesh repair and improvement commands but the problem persists. I have also tried it with K-omega model but the problem continues to exist. I have tried with all triangles and multizone quad-tri mesh with body sizing. Inflation was also done. Last edited by adnanshahariar; April 5, 2018 at 20:01. Reason: There are some errors |
divergence amg solver, momentum equation, multiphase flow, velocity component |
AMG solver divergence; | Mike | FLUENT | 17 | December 14, 2015 13:01 |
Divergence detected in AMG solver : epsilion | maheshbabu | FLUENT | 0 | April 4, 2014 05:54 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Divergence detected in AMG solver | tiankongasd | FLUENT | 2 | March 28, 2013 12:34 |
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature | bubuchacha | FLUENT | 6 | February 26, 2013 03:30 |
