Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Flow water in channel with zero speed
Old   March 21, 2018, 08:30
Question Flow water in channel with zero speed
Illia Leptiukhov
illia is on a distinguished road
Hi users. Can you help me, what's kind of parameters i must turn on for modelling water flow in vertical channel with zero speed? The water must flow down on the wall, with influence of gravity only. I turned on the gravity, VoF model, k-epsilon model, added 2 phases (air primary, water secondary), but on the end of modelling, water doesn't flow. I modelled flow with velocity 0.5 m/s, there all is ok. Who worked with gidraulic flow, please hint me. Thanks. I attached the pictures of channel with water velocity 0.5m/s. If you need something else - tell me.
illia is offline   Reply With Quote
channel flow, flow 3d, multiphase flow, vof model
Advice on open channel flow for an water intake chamber jcox675 CFX 11 September 4, 2014 08:28
compressible low speed channel flow -Ali OpenFOAM Running, Solving & CFD 11 May 9, 2013 08:40
Increasing level of water two-Phase Channel Flow nore5 OpenFOAM Running, Solving & CFD 16 March 25, 2013 04:24
OpenFOAM open channel flow downsteam boundary condition Brickman OpenFOAM Running, Solving & CFD 2 November 5, 2012 21:14
water channel flow with non symmetrical solution bruce OpenFOAM Running, Solving & CFD 1 October 21, 2011 13:00
