how to create three phase zones on vof fluent |
March 3, 2018, 08:06 |
ebubekir kaldirim
I've been trying to add three phase zones on my 2D geometry.JPG (WHERE THE RED ZONE IS AIR AND BLUE IS WATER. I WOULD WANT TO ADD A 4 LITER VOLUME AIR ON THE BOTTOM OF THE PIPE) geometry, that is a pipe of 10 meters long and with 15 cm diameter also, on the top of the geometry there is a box looking with a 5 meter height and 50 cm diameter. the pipe will be full of water except for the bottom that will contain 4 liters of air and on the top of the pipe will contain another air zone. if any one can guide me step by step i will appreciate it. Best regards, Ebu |
March 19, 2018, 12:36 |
Hamed Abdul Majeed
Rep Power: 14 |
I don't know if you actually want to separate zones just to define the phases.
An easy option would be: Adapt>Mark/Adapt cells>Region. Select a region, and you could use this region to define any phase. Note: Do this after you have initialized. However, if you want to create zones, in the marked region above: Zone>Separate>cells And select the region you just marked to create separate zone. Tip: Do a basic VOF tutorial of FLuent...it explains this basic stuff. S Tutorial 18. Using the VOF Model |
Patching Second Phase Region in Fluent V13 VOF Model | sda | FLUENT | 19 | July 3, 2022 07:00 |
How To Create Fowcs William Hawkings Surface in Fluent? | marinkobezu | FLUENT | 7 | October 25, 2018 11:51 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 07:47 |
VOF for single phase? | vuccj7 | FLUENT | 0 | April 20, 2011 20:59 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
