Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
2d multi-phase dynamic mesh
Old   February 2, 2018, 11:40
Default 2d multi-phase dynamic mesh
Wael
saadyw is on a distinguished road
Hi experts,
My case is a 2d multi-phase dynamic mesh for a piston cylinder arrangement partially filled with water and traps a certain amount of compressed air in a chamber. I can set the phases with mark regions options as attached in the picture
Due to piston motion, the water level should go up and down due to the change in volume which does not happen.
Can anyone help in this ?
By the way, I set the water density and speed of sound as user-defined function and the boundary between the inner cylinder and the annular one is set as interior. I have attached a copy with the main BC
Regards
Wael
saadyw is offline   Reply With Quote
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
potentialFreeSurfaceFoam with Dynamic Mesh GuilhermeMP OpenFOAM Programming & Development 1 October 6, 2013 04:05
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
