Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
backflow volume fraction in pressure outlet
Old   January 23, 2018, 05:11
Default backflow volume fraction in pressure outlet
haghshenasfard's Avatar
a
haghshenasfard is on a distinguished road
in multiphase modeling, the backflow volume fraction should be defined at the pressure outlet, Is it right that the value being set as "1" means the second phase total reflux?
what about the value being set as "0.5"?
What should we do if we want exit of one of species in outlet?
haghshenasfard is offline   Reply With Quote
Old   March 5, 2018, 11:10
Cees Haringa
CeesH is on a distinguished road
You should set it to what is the most realistic for your problem. If you have, say, a column with a gas-filled headspace, then backflow should be 100% gas, Just regard it as an additional inlet - in case the flow would be inward here, what would be flowing back in?
CeesH is offline   Reply With Quote
Generating water waves - backflow at the outlet Luke92 CFX 1 November 18, 2017 06:27
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Finding Volume fraction at outlet when it changes its phase. praveen.jpk Main CFD Forum 1 August 18, 2014 08:18
Backflow occuring at a pressure outlet? Dave FLUENT 1 August 12, 2004 18:39
