Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Realisation of density for melting process of ice
Old   January 5, 2018, 03:27
Default Realisation of density for melting process of ice
niewiemnic
spalartallmaras is on a distinguished road
now I tried to simulate a melting process of ice. I could show the result of liquid fraction of ice with solidification/melting function.
But the problem is, the density of ice is almost constant, but the density of water is not constant but depend on temperature.
I have to show the change of density during melting.
That means I have to realise the density jump up from 0.9167 g/cm3 to 0.9998 g/cm³ at the temperature exact 0 grad Celsius, that means at the exact point of phase change! (Ice -> Water)
Thank you!
spalartallmaras is offline   Reply With Quote
fluent, ice, melting, multiphase flow, water
UDF for modifying density of mixture phase during the calculating process sola86 Fluent UDF and Scheme Programming 2 May 28, 2019 10:24
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
Combustion in ICE - Weller model roadracer Siemens 1 July 22, 2009 05:54
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 10:53
