January 3, 2018, 12:02 |
Fluid Flow into Still Air from Faucet
Jackie Yik
I am having difficulties simulating water jetting from a capillary or faucet into still air and breaking up. To me, this should not be so difficult to simulate, but it has proven very time consuming.
I want to simulate the first two regimes of a jet breakup stability curve as shown in the first two boxes of the first attachment (Dumouchel 2008) in 3D. I have simplified the geometry for this with just a cylinder acting as the free space. I have shown the top of the cylinder and meshing I am currently using in the attachments. At the top of the cylinder I have the orifice of the faucet/capillary which is the finer meshed area. I used a parabaloid UDF for the inlet velocity profile profile and set the peak velocity as 2.38m/s. Water is the material that is coming from the faucet and air is what fills the domain. With my current properties I have a Reynolds number = 711 and Weber number of the gas = 0.0286. This falls into the first box of the attachment, Reyleigh regime, but the current simulation (also in attachments) looks more like the second box, first wind-induced regime. It took 10 days to run which is ridiculous and I have yet to see a drop break off, not to mention that I suspect the solution is not correct. Here is a little more information and settings I used: Meshing Total Nodes: 941200 Total Elements: Hexahedrals: 927276; and Quadrilaterals: 26992 **According to ICEM CFD Pre-meshing information before I converted it into mesh** Minimum Orthogonal Quality = 0.738859 Maximum Ortho Skew = 0.261141 Maximum Aspect Ratio = 16.5582 Setup General Pressure-based, Transient, gravity pulling fluid down Model VOF, 2 phases Level Set selected K-epsilon turbulence, realizable, standard wall functions Surface tension on (obviously) but no wall adhesion Boundary Conditions top of cylinder where orifice inlet is and sides set as free slip wall bottom of cylinder set as pressure outlet **Tried setting the free slip walls as pressure outlets as well, but not much difference to solution** Solution PISO scheme Gradient: Least Squares Cell Based Pressure: PRESTO! Momentum: Second Order Upwind Volume Fraction: Geo-Reconstruct Turbulent Kinetic Energy, Turbulent Dissipation Rate, and Level-set Function: Second Order Upwind URF kept default; did change them before but simulation is too slow to see much difference Convergence set to default 1e-3 Initialization entire cylinder filled with air Calculation Timestep Variable method with Global Courant Number = 1 (was set to 0.5 before) **Courant Number = 2 seemed to diverge sometime after 5000 or so time steps and I ran it over the holidays so I did not want it to diverge.** Time Step Size = ranges from 2e-7 to 7e-8 max Iteration/Time Step = 50 I have tried looking around to speed up this simulation, but nothings has worked. I have looked at other papers on simulations similar to this (in 2D however) and they usually use similar settings. My computer's processing power is not the issue here I think because I am doing this on a 64GB RAM and 2 Intel Xeon processors workstation. My main problem right now is that it takes too long to run. Each run of the simulation takes so long I do not have time to diagnose it. I hope I do not have to run a simulation for two weeks and then check to see if it is right, change some minor detail, and run it again for two more weeks. There are a few things I have considered while looking around but I am not too sure:
I am in quite a pickle and I do not know what to do. The only license I have is an academic one which does not allow customer support for this, I think, and I cannot run more than one simulation at a time so I cannot try different things out at the same time. Unfortunately 2D is not an option as I need the results for some other application. If there are any Fluent experts out there that might be able to help or some other post/documentation/resource that would be useful (I swear I tried using the search bar first!) or someone I could contact that would be able to help that would be great! Please let me know or private message me; I have been trying to do this for 3 months with little progress. |
January 5, 2018, 14:26 |
Rep Power: 8 |
Hello Jackie,
Have you experimented with Implicit vs Explicit Volume Fraction Formulation (in Multiphase Model dialog box)? Explicit will be best suited for accuracy, but implicit may offer time savings by allowing a larger time step. May be worth playing with if you haven't. Also, I didn't see anything about serial/parallel settings. I believe the academic license still provides for parallel processing, which will speed up your runs substantially if you aren't familiar.
"The more you do what you're already doing, the more you'll get what you've already got." |
January 8, 2018, 11:50 |
Jackie Yik
I haven't experimented with Explicit/Implicit yet, maybe I will look into that, thanks.
I know about parallel computing vs serial and I am using parallel. What I meant was I don't know if I can run two or more independent simulations at the same time. |
breakup length, droplet formation, jetting, reyleigh regime, still air |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Average Rising Velocity as boundary condition | Floing | CFX | 11 | August 21, 2016 06:47 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 04:53 |
Simulation of air flow in a chamber | Issa | CFX | 3 | November 23, 2009 18:16 |
