December 8, 2017, 12:11 |
Defining two phases in a CLOSED system
Marc
Rep Power: 11 |
Hello folks.
I want to simulate the dispersion of dust coming from a powder lying on the bottom of a test tube. The system is closed: NO inlet and no outlet. I defined phase 1 as air and phase 2 as alumina. I divided the geometry of the powder into two parts: the 6 first milimeters of the test tube "PowderBed" and the rest of the test tube "RestTestTube". I then went into "Cell Zone Conditions". The problem is that if I define "phase 2" as the phase of "PowderBed", it automatically becomes also the phase of "RestTestTube". In other words, regardless of what I do, in "Cell Zone Conditions", "PowderBed" and "RestTestTube" have always exactly the same features. Is there anything I can do to make FLUENT understand that the region "PowderBed" is filled with alumina 'phase 2) whereas "RestTestTube" is filled with air? I hope I've been clear enough. Many thanks for your answers. |
December 11, 2017, 05:23 |
annan
Rep Power: 10 |
Hey,
What models are you using ? When you say that you divided the tube into two zones, have you done it using "Mark/Adapt Cells" => "Region" ... etc. ? if this is what you have done, you can try and use Patch in "solution initialization" to put the condition you want. Hope this will do. |
System Build Advice for FEA | cycleback | Hardware | 1 | February 8, 2013 21:53 |
Defining local coordinate system | bastil | OpenFOAM Pre-Processing | 11 | August 8, 2011 09:26 |
Boundary Condition for Closed System | hars | Main CFD Forum | 0 | April 21, 2009 05:50 |
2 phases flow system in cylindrical pipe | ivan | FLUENT | 3 | February 25, 2006 12:52 |
closed system calculation | Neil MacLeod | Main CFD Forum | 1 | May 13, 1999 16:47 |
