December 8, 2017, 10:27 |
Surface Errors
Erick
Rep Power: 9 |
I am trying to run a simulation that seems to have some old geometry defined inside fluent. I get the following type errors when setting up data exports:
I saved everything and re-opened workbench from scratch then the solution: When it opens up I get a whole slew of errors: Preparing mesh for display... Error at host: zone-surface: invalid thread[2] Error at Node 0: zone-surface: invalid thread[2] Error at Node 1: zone-surface: invalid thread[2] Error at Node 2: zone-surface: invalid thread[2] Error at Node 3: zone-surface: invalid thread[2] Error at Node 4: zone-surface: invalid thread[2] Error at Node 5: zone-surface: invalid thread[2] Error at Node 6: zone-surface: invalid thread[2] Error at Node 7: zone-surface: invalid thread[2] Error: zone-surface: invalid thread[2] Error Object: #f I've tracked it back to stale surface definitions that exist from the previous geometry with multiple bodies that I swapped out. I have found where I can manage surfaces via the Surface->Manage menu where I can delete them manually. However some of my new surfaces use similar names and I can't tell which ones are the stale surface definition to delete. Is there a way to cause fluent to reload and repopulate the list of surfaces automatically? |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
