Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
how to change richardson number
Old   October 10, 2017, 11:25
Default how to change richardson number
Mohamad
azorit is on a distinguished road
hi
does anyone know how to input (or change) richardson number in fluent ?
my model is two phase mixed convection nanofluid.
mixture model (water+AL2O3)
azorit is offline   Reply With Quote
Old   October 25, 2017, 03:17
Default richardson number
yun
gush is on a distinguished road
there is no where that you can write down the richardson number you wish to work on fluent.
richardson number come from Gr/Re^2 (if you dont know what these are then find a heat transfer book or google it)
you can calculate the current richardson number of your model by velocity, temperature etc...
and if you want to change it then you need to change those values accordingly.
gush is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
MPI run run fails of quadcore openfoam2.4 Priya Somasundaran OpenFOAM Running, Solving & CFD 3 January 25, 2016 09:50
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
