Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Bubble column
Old   September 9, 2017, 21:16
Unhappy Bubble column
Mohsen
Mohsen1991 is on a distinguished road
Hi guys
I tried to simulate a air-water column in FLUENT with Euler model that coupled with Population Blance equation and standard K-epsilon for turbulance model but I get a lots of AMG divergence errors... it is done in 3D and 2D models but it seems that errors are similar
some times it's about Bin fraction of inlet air and some times it is about K and epsilon equation
problem :
unsteady state
a cylinder which air with a specific constant diameter injected with 0.085 m/s
and no sperger is used in inlet and no water in inlet
outlet in pressure outlet and with back flow of 1 for air phase
and one thing ... I used a discrete procedure in PBE with 10 bins diameter
it is necessary that I say a mesh file is edited so much only effect of element is on how soon I get that erros ...
Mohsen1991 is offline   Reply With Quote
Old   February 10, 2018, 04:48
Default PBM in 2 phase column
Sunil Kumar Sah
sunilsah2011 is on a distinguished road
I encountered the same problem. Were you able to solve it.
Please Help
sunilsah2011 is offline   Reply With Quote
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 07:01
Problem: bubble column with twoPhaseEulerFoam hester OpenFOAM Running, Solving & CFD 6 January 22, 2016 13:25
2D bubble rising through a column of water vof64 Fluent Multiphase 0 August 20, 2014 00:42
bubble column ken FLUENT 1 June 30, 2013 02:18
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 09:59
