Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase VOF Film Formation on Cylinder partly immersed in ink
Old   August 15, 2017, 17:17
Default Multiphase VOF Film Formation on Cylinder partly immersed in ink
Christian Sauder
chris1009 is on a distinguished road
Hey,
i am new to CFD and this forum and i hope you can help me with some troubles i have in building up my fluid simulation for a parameter study.
I managed to get the transient simulation runing in ANSYS FLuent 17.2 within ANSYS Workbench but have problems with the evaluation of the velocity profile at a specific location on the cylinder surface in CFD-Post.
Right now i use an isoclip vith Volume Fraction Phase 2 >= 0.5 and use an "length()@Location"-Expression to get the film thickness. This works perfectly fine. But when i want to look at the Velocity profile at this location the results from the vector plot on my iso clip and the results from bilding a chart with the velocity against the length of the iso clip are different. The Vector plot looks plaussible, the chart not. I think it might be because of the conservative setting for the velocity variable. Right now i can't change it to hybrid and i dont know why.
Although exporting the velocity at the iso clip an building the chart in Excel gives plaussible results. Since i want the results to be used for a load in a seperate mechanical simulation it would be good to have some sort of a polynominal function that gives me the velocity as a parameter of length along the iso clip.
Do you have any suggestions how i can get this working automatically when running my DoE with the least amount of effort? The Parameters of the Fluid Simulation that will be investigated are the viscosity and density of the ink and the diameter and rotational speed of the cylinder.
Thanks in advance for any tip.
Chris
chris1009 is offline   Reply With Quote
Using VOF model and Lagrangian Multiphase in the same simulation ganesh_krishnan STAR-CCM+ 2 March 17, 2017 02:34
VOF multiphase - Validity of Fluent ? manxu FLUENT 2 January 2, 2014 12:17
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 09:41
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) balu@gold6 FLUENT 4 July 26, 2012 11:37
VOF transfer - multiphase flow karthik Main CFD Forum 4 February 2, 2006 02:25
