convergence issues in gas-solid flow simulation in Fluent |
July 21, 2017, 07:20 |
Santosh
Rep Power: 9 |
I am trying to simulate gas-solid two phase flow in an 2D axisymmetric vertical pipe using two fluid model approach of Ansys fluent. I am using the granular PDE for the solid phase. As per the fluent manual first I am simulating the single phase (air) and then switching to two phase. Single phase simulation is converging properly; the mass flux criterion is also being satisfied. However the moment I switch on the solid phase the residual of granular temperature equation is not falling below 10^-03 and then the residuals of solid phase momentum are also causing problem even with a time step of 10^-06.
Any Help? Thanks |
November 11, 2018, 17:42 |
#2 | |
Muhammad Ali Uzair
Rep Power: 9 |
I am facing the same problem with PDE for granular temperature. The simulation diverges. If you solved the problem, could you please guide me. Best |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Fluent Simulation of gas mixture in the pipe | free.man | FLUENT | 1 | November 26, 2016 01:59 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
