Non-newtonian flow in open tank doesn't fall due to gravity |
July 4, 2017, 20:41 |
Alexis Yanez
Hi! I'm modeling an open tank, using mutiphase model, phase1: air; phase2: non-newtonian fluid.
My problem is the flow throught the hole in the separating plate goes up to the top of the tank, like no gravity was set (in apparience). I have checked a lot of settings and I think they are fine: - Non-newtonian model activated and choosed - Negative gravity on Y axis - Pressure 1.73psig as boundary condition on inlet - Pressure 0psig as boundary condition on outlet - Pressure 0psig as boundary condition on ambient (top of tank) - Air density 1225 kg/m3 as Operation Condition - Patching in bottom region of tank, liquid fraction volume = 1 - 900 iterations was executed - When i try modeling water as Phase 1, results appear to be correct (fluid goes up to the bottom oulet). I will be grateful if someone can help to find the cause of error. Thanks! Last edited by ayanezc; July 9, 2017 at 18:55. Reason: Delete image |
July 9, 2017, 18:56 |
Alexis Yanez
Solved, missing phase asignation to phase 2. Thanks.
open tank multiphase |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 17:26 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
