Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
solution running slow
Old   July 2, 2017, 13:38
Default solution running slow
sebastian bergman
Tushar_Telmasre is on a distinguished road
Dear all,
I set a simulation in fluent with solidification model and VOF model. First I used a rectangular domain and the solution I got was fine and quick. After completing that I set up the same physics and the same models and same boundary conditions, but now using a Trapezoidal Geometry. here I am getting the iterations are sluggish. The simulation is taking forever to run.
What can be the reason? Same physics and boundary condition are giving me very different solution times, the only difference being the rectangular and trapezoidal geometries.
I think, it is because of the difference between mesh elements. In rectangular geometry all the elements are rectangular and in trapezoidal geometry the elements are combination of rectangular and triangular elements. well, If that is the case how to solve the problem?
Using system
Intel core - i7 6th generation
16Gbs of RAM
no Graphics card
Tushar_Telmasre is offline   Reply With Quote
Old   July 18, 2017, 13:33
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Did you run a grid independence test? Check the results from various mesh sizes and see how your desired parameters change.
How much change are you actually expecting in the results between the two models? Do the results so far match or is the issue just the run time?
-BB
bhargavbharathan is offline   Reply With Quote
ANAYS Workbench stop running the solution without error hollylui ANSYS 0 December 12, 2016 05:52
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Slow Transient Solution scoobysimon FLUENT 1 March 21, 2014 04:19
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 08:52
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
