June 24, 2017, 03:28 |
Viewing particle distributions on a plane
Rep Power: 10 |
Hi all, could I know how to obtain the particle distribution on a plane as shown in the image?
Thank you. contour.png |
June 28, 2017, 08:36 |
Alexander
Rep Power: 9 |
Create surface to display (surface - create - plane)
display - contours - DPM concentration (if you use discrete phase model) display - contours - phases - volume fraction (in case of Euler models) |
June 29, 2017, 03:49 |
Ken
Rep Power: 11 |
hi there, i dont see any contour options under the display option (at the top row). so i was wondering if you are referring to the Results (left column option) - Graphics and animations - Contours?
June 29, 2017, 04:57 |
Alexander
Rep Power: 9 |
Yep, that’s right
July 19, 2017, 04:09 |
Rep Power: 10 |
Thank you so much sfn. Really appreciate it.
I'm so sorry that I have another question. How can I view my result as below? I'm using DPM to simulate the particle. |
Viewing particle distributions on a plane | kywong5 | Fluent UDF and Scheme Programming | 0 | June 24, 2017 03:18 |
particle number/mass flux across a plane | cfdopenfoam | OpenFOAM Running, Solving & CFD | 1 | May 19, 2017 19:32 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 17:30 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
