Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem with fixed vapor temperature
Old   June 20, 2017, 12:21
Default Problem with fixed vapor temperature
Aladin&Fluent is on a distinguished road
I am new to CFD-online, highly grateful to you all for your volunteer help.
I am trying to setup a subcooled pool boiling of water and vapor in a vertical pipe (5cm inner diameter) 1m high. A small heater is inserted into the bottom of the pipe to make boiling. I use two-fluid with RPI models. I also model the conjugate heat transfer through the pipe wall.
I set the vapor temperature in the fluid zone (inside the pipe) to a fixed value, i.e. 373.15K then run a transient case.
The problem is that when I look at the calculated static temperature of the vapor phase, it never shows the fixed value of 373.15K but a range from 341K (close to some parts of the pipe wall) to 396K (close to the top of the heater surface).
Could anybody have comments or explain me this problem? Thank you a lot.
Aladin&Fluent is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
the problem of the tutorial 9- Optimal Shape Design of a Fixed Wing lbfhappy SU2 Shape Design 1 November 11, 2016 05:17
Heat Transfert, mixing problem Wazdq CFX 8 November 7, 2016 06:44
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
