Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Wing surface check
Old   June 6, 2017, 16:37
Default Wing surface check
Marc
krvm is on a distinguished road
Hi everyone, I am performing a simulation in ANSYS Fluent where I want to plot lift versus drag coefficient, at several angles of attack, over a NACA 0012 airfoil.
As a reference, I am using Abbott's data (1959), where it says that for alpha = 10 degrees, Reynolds = 3e06 and assuming K-omega SST turbulence hypotheses, the values should be: Cl = 1.08, Cd = 0.015. I'm getting the right value for Cl, but my Cd lays at around 0.04.
I asked my teacher about it and he said it could be due to an error in the wing surface I am using. Thing is, I don't know how to check or change this value, and I'd appreciate any help that you could give me. Thanks in advance!
krvm is offline   Reply With Quote
airfoil 2d, drag coefficient, lift coefficient, wing surface
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 16:17
Structured Meshing of Wing Surface Naruto Pointwise & Gridgen 6 September 28, 2017 12:34
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 02:44
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
