Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
DPM volume fraction
Old   May 21, 2017, 07:49
Default DPM volume fraction
akbar.mech is on a distinguished road
hello every body
i am simulating particle injection in a continuous phase which is air and i am using DPM model in ansys fluent 15. the continuous phase is in steady state and the discrete phase is unsteady. as you know DPM can be used when the volume fraction of discrete phase is less than 10%. my question is:
how can i calculate the volume fraction for dispersed phase.
i appreciate your concern
akbar.mech is offline   Reply With Quote
Old   July 18, 2017, 13:46
Bhargav Bharathan
bhargavbharathan is on a distinguished road
You need to calculate the volume fraction as a percentage of your flow rate. If you have 100 kg/s flow rate and a 10% solid concentration then the sand flow rate would be 10 kg/s.
-BB
bhargavbharathan is offline   Reply With Quote
How to use a UDF to set the volume fraction in the cells next to a wall? DF15 Fluent UDF and Scheme Programming 33 August 20, 2020 14:36
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Controlling fluid volume fraction over time at the inlet of a pipe Gwench Fluent Multiphase 1 December 9, 2015 09:59
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 07:17
