Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Three phase flow in pipes simulation
Old   May 17, 2017, 00:32
Default Three phase flow in pipes simulation
Waqas
Waqas Yaqub is on a distinguished road
Hello guys
Good day.
I want to simulate gas-liquid-liquid three phase flow through pipes in ANSYS fluent.
i want to know that, the multi-phase models in fluent are capable of simulating three phase flow or not?
If yes, which multi-phase model should be used for simulations.
Your kind suggestions are needed
Waqas Yaqub is offline   Reply With Quote
Old   May 17, 2017, 01:44
Svetlana Tkachenko
Svetlana is on a distinguished road
Yes, ANSYS Fluent can do three phase flow. The flow regimes are listed here and after you know your flow type you can choose a model here. Here is the relevant chapter from the user manual: here.
However please check literature as a good literature review for every problem possible is not contained in the ANSYS FLUENT manuals. An in-depth literature review on your topic of interest would save you a lot of time and ensure that your results are accurate and relevant. If you would like further assistance on choosing a good model, please describe your problem that you are solving.
Svetlana is offline   Reply With Quote
Old   May 17, 2017, 02:29
Waqas
Thanks for the guidance
According to the manual. The multi-phase model should be selected on the basis of flow regime. And the flow regimes are majorly dependent on the flow rates of the phases. In that case, the type of model should be changed with the change in flow regime??
Bubble plume simulation, multi phase flow Artvandelay Main CFD Forum 5 August 23, 2018 04:52
Two phase flow problem. andyraq Fluent Multiphase 4 August 21, 2016 22:57
Two phase Via Solidworks Flow Simulation sakhadem Main CFD Forum 1 August 10, 2016 18:12
two-phase flow with a single phase simulation caunima Fluent Multiphase 0 October 28, 2013 03:42
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 17:29
