Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to calculate viscous dissipation in Fluent?
Old   May 14, 2017, 18:07
Default How to calculate viscous dissipation in Fluent?
Hossein1 is on a distinguished road
Using VOF ith a laminar model, I'm simulating collision of a droplet and a spherical particle. The particle moves very fast (~7 m/s) and so penetrates into the falling droplet and deforms it to a thin liquid film (i.e. a lamella). Please see the attached picture for an overview of the process. Does anyone know what I need to do in Fluent to calculate the "viscous dissipation" takes place in the liquid phase during deformation (i.e from the impact moment until lamella detachment from the particle)?
Thank you!
PS. If there is a way by which I can have access to velocity field only inside the lamella (i.e. within the liquid phase only), then I can probably use the 'calculator device' in Fluent to calculate the velocity derivative to have phi function and then use the attached formula to calculate the energy dissipation. Is there any way to work only with the velocity inside the lamella?
Hossein1 is offline   Reply With Quote
Old   July 18, 2017, 13:42
Bhargav Bharathan
bhargavbharathan is on a distinguished road
If you are using Fluent 17 and later, the viscous dissipation can be turned on in Models->Energy.
-BB
bhargavbharathan is offline   Reply With Quote
droplet impact, viscous dissipation, vof simulation
How Fluent calculate Y+ for Multi fluids model mohibanwar Fluent Multiphase 1 August 29, 2015 21:40
How does fluent discretize the viscous term? motorbean FLUENT 3 August 25, 2015 17:38
How to compute the viscous dissipation term yhy20081016 Main CFD Forum 2 December 17, 2013 23:26
IS FLUENT A VISCOUS SOLVER?? karthik FLUENT 4 August 1, 2005 13:49
Viscous heat dissipation muhammad asif Main CFD Forum 0 July 25, 1998 05:00
