VoF Model, miscible fluids, mass transfer rate |
May 12, 2017, 07:48 |
Yu Lu
Rep Power: 11 |
I'm simulating a situation where a channel is filled with one static fluid (fluid 1) and another fluid (fluid 2) (which is miscible to the one filling the channel) is injected into the channel to displace the first one.
I care about the interfacial phenomena at between these two fluids So I'm planning using laminar VoF model (which works fine for my immiscible cases). For simple fluids, for example a glycerol solution (Say 86% wt.) as Fluid 1 and water as fluid 2. The only place I found to put the diffusion/mass transfer between these two fluid is the "mass" tab in the phase interaction. What exactly is this value I should put in? I was guessing a constant mass transfer rate but in the Fluent manual it says constant rate is not available for VoF model. Some suggestions on how to work out this value for my situation or the actual value I should use and its source will be much appreciated! Thanks a lot! |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Solver for Multispecies Mass Transfer induced Domain growth/shrinkage | MonoC | OpenFOAM Running, Solving & CFD | 1 | March 13, 2016 07:41 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
Source terms due to mass transfer in VOF model | ssamton | FLUENT | 0 | March 5, 2012 00:03 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
