May 5, 2017, 08:30 |
Did anyone know someting about bubble rising
Liangliang Tang
Rep Power: 10 |
I used VOF did some work about bubble rising. But find some problem: when bubble's dimension is small(like 1mm or 1.5mm), the result seems not right. And i did bigger dimension(like 2mm or 3mm),the result seems well. I don't know why. The wrong situation picture showed here. Regards, Tang. |
May 5, 2017, 08:42 |
May 5, 2017, 09:26 |
#3 | |
Liangliang Tang
Rep Power: 10 |
Did I get thing thing wrong? I use VOF ,Implict Body Foce, Tension=0.072, presure outlet.... |
May 6, 2017, 04:40 |
David Chou
Rep Power: 11 |
1. try to reduce the time-step and mesh size
2. try to change momentum method to 2 order upwind in the "solution method" |
May 6, 2017, 08:12 |
Liangliang Tang
Rep Power: 10 |
Rising bubble with interFoam | tayo | OpenFOAM Running, Solving & CFD | 16 | March 12, 2020 13:11 |
A rising bubble in a stagnant liquid with two-fluid-model | fs82 | OpenFOAM Running, Solving & CFD | 30 | August 18, 2016 13:27 |
bubble rising problem | swamysrikanth | ANSYS Meshing & Geometry | 3 | May 31, 2016 12:09 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 20, 2014 00:42 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 09:59 |
