Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
UDF can't run
Old   April 24, 2017, 23:17
Post UDF can't run
slyan
slyan0913 is on a distinguished road
Error:
E:\ANSYS\ANSYSI~1\v145\fluent\fluent14.5.0\win64\2 ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
who meet this error same as me? I just add an UDF for PBM model.
DEFINE_PB_GROWTH_RATE(growth_rate, cell, thread,d_1)
/* d_1 can be used if size-dependent growth is needed */
/* When using SMM, only size-independent or linear growth is allowed */
real G, w;
real P,solute_mass_frac,solubility;
//Thread *tc = THREAD_SUPER_THREAD(thread); /*obtain mixture thread */
//Thread **pt = THREAD_SUB_THREADS(tc); /* pointer to sub_threads */
Thread *pt = THREAD_SUB_THREAD(thread,0);
solute_mass_frac = C_YI(cell,pt,0); /* mass fraction of solute in primary phase (solvent) */
P = C_P(cell,pt); /* Pressure of primary phase in Pa */
solubility = 9.708*P/1.e6+1.4;/* Solubility Law relating equilibrium solute mole fraction to pressure,S:g/kg,P:MPa*/
w=solubility/(solubility+1000);
if (solute_mass_frac < w)
G = 0.;
else
G = 9.04206e-16*exp(w/0.00327)+6.1679e-5;
return G;
This is my UDF, who can tell me why?
slyan0913 is offline   Reply With Quote
pbm model udf
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 04:40
