April 20, 2017, 11:25 |
Eulerian wall film: missing mass
Alexey
Rep Power: 9 |
Dear Colleagues,
I have a problem with modelling of ewf through dpm collection. When I do "sum" in "volume integrals" window the calculated total mass of film doesn't correspond to injection mass (subtracting droplets mass in flow). Anybody had the same problem and how did you solve it? I changed time steps, urf, dpm and ewf solution options but unsuccessfully. Best regards, Mr Bennet. |
June 7, 2017, 12:57 |
Mass low in EWF model
pkumar
Rep Power: 16 |
Hi there,
Were you able to solve the issue? I am experiencing similar problem of mass loss. Thanks, Puru |
June 7, 2017, 13:39 |
Alexey
Rep Power: 9 |
June 8, 2017, 06:58 |
Hi
I have water evaporate need to be condense on the glass Is it required to activate the Eulieran wall film please? I can't intialize it says can't intialize Eulieran wall film!!! Sent from my SM-G900I using CFD Online Forum mobile app |
October 27, 2019, 21:13 |
Jinxiang xi
Hello MrBennet and Puru,
Have you solved this problem of mass inconsistency between injected mass and film mass? From version 18, there is no option to specify minimal film thickness. The film mass depends a lot on the maximum film thickness, while is independent of the mass rate. Have you found a method to ensure the mass consistency between injection and deposited film in V18 or V19? BTW, have you found a method to consider the liquid-wall interaction, which determines the maximal film thickness? Regards, Jinxiang |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
BUG: "Unable to read Transient airflow+Transient DPM and Eulerian wall film .gz file" | Jeeloong | FLUENT | 0 | November 27, 2015 11:38 |
How to monitor Eulerian Wall Film Convergence | Jeeloong | FLUENT | 0 | October 26, 2015 11:42 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
