Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluent VOF Vertical Slug Flow
Old   April 14, 2017, 22:11
Default Fluent VOF Vertical Slug Flow
A K Chetty
akchetty is on a distinguished road
I have been trying to perform vertical air-glycerol slug flow simulations in Fluent using VOF and was thinking if anyone can help or give an advice regarding the issue I am facing right now. The terminal velocity I am getting for a rising taylor bubble in stagnant glycerol solution is only half of what it is supposed to be according to literature and other CFD results in the paper (Numerical Study of Hydrodynamic Characteristics of Gas–Liquid Slug Flow in Vertical Pipes etc). I tried following the methodology people have used in the literature, the one of solving the two-phase set up in a frame moving with the Taylor bubble. So I have the two walls moving downwards (2-D domain ) along with the liquid (top- velocity inlet and bottom - outflow) at terminal velocity of the taylor bubble (say 0.14 m/s). Unless I use a velocity value almost half of the correct value from literature, my Taylor bubble either moves up or down the domain. The bubble should remain stationary if the walls are moving with correct velocities which is the terminal velocity of the bubble. I tried using stationary domain but still I am having the same problem of half the terminal velocity. I am using pipe diameters of 19-22 mm and mesh sizes of 1-0.5 mm and initially start with a film thickness calculated from empirical correlations and start with a bubble length of 3.5 times the bubble diameter. My solution converges, but terminal velocities are off by half. Any idea or suggestion regarding where I may be doing a mistake ? Looking forward to your reply. Thank you.
akchetty is offline   Reply With Quote
Help with slug flow simulation. Kes FLUENT 3 November 9, 2019 22:39
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Need advice and/or tutorials for Fluent VOF method two phase closed thermosyphon flow ic3lemon Fluent Multiphase 1 November 6, 2016 08:34
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Viscoelastic flow modeling in Fluent Ankur Navra FLUENT 3 July 26, 2013 06:56
