Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian method-Critical Heat Flux(CHF) Problem!
Old   April 8, 2017, 12:04
Exclamation Eulerian method-Critical Heat Flux(CHF) Problem!
Mehmet
japon3545 is on a distinguished road
Hello everyone,
I want to estimate the critical heat flux of a two-phase flow in a flat mini channel (2mm x 2mm x 200mm). Mesh number is 234000. More details about the model setting are given below.
Model Settings:
Steady State
Eulerian Multiphase Model- Boiling Model - Critical Heat Flux (Primary Phase = Liquid Water; Secondary Phase = Water Vapor)
Realizable k-epsilon model with Enhanced Wall Function
Phase Interactionsrag -ishii
Scheme: Phase Coupled Simple
Momentum-Volume Fraction,Turbulent Kinetic Energy,Dissipation Rate and Energy:QUICK
Velocity inlet 0.2 m/s apprx. G=200 kg/m2s
Heat Flux: I applied between 40-100 kW/m2
When I make a solution like this, I can not see the phase change. In addition, vf phase 2 and energy p2 values in the residual graph are always zero.
I have tried dividing the phase intervals like the VOF model by adapt. When I do this, the system gives the error of divergence.
what should I do?
japon3545 is offline   Reply With Quote
Problem with Turbulent Heat Flux Temperature boundary condition Manuel CFD OpenFOAM Running, Solving & CFD 11 March 17, 2016 16:12
Problem with snGrad() for heat flux. SKLee OpenFOAM Programming & Development 4 March 4, 2014 23:46
Problem with buoyancy and heat generation Jaguar CFX 8 May 12, 2011 19:54
problem with heat flux in the wall gholamghar FLUENT 1 September 14, 2010 08:47
Heat Generation as time dependent problem Denis Kadito FLUENT 0 April 17, 2001 17:28
