March 21, 2017, 02:13 |
Problem with 2-Way FSI Multiphase Simulation
Julian
Rep Power: 9 |
Hello everybody,
I have set up a 2-way FSI Simulation. I can start it without any trouble if Multiphase is off. But as soon as I choose Volume of Fluid (2 Phases; Formulation->Implicit; Interface Modelling/Type->Sharp) the simulation doesn't start anymore. Phase1->air Phase2->oil PhaseInteractions-> shear stress constant value Following appears in the Fluent solution information: [...] Preparing mesh for display... Done. Setting Post Processing and Surfaces information ... Done. Initialization based on settings... Deleting Client...done Shutting down Server...done Error: Rpc Communication failure during SyncManager:YieldToken call at cortexmpc.c:294 [...] I think it must be a problem with initialization. I use Standard Initalization and patch a region afterwards. Of course I can provide more detail about the setup if needed. I'm happy about any help. Thanks a lot in advance, Juli |
March 21, 2017, 03:54 |
March 21, 2017, 05:40 |
#3 | |
Julian
Rep Power: 9 |
March 21, 2017, 06:27 |
Geometry Problem?
Julian
Rep Power: 9 |
Maybe the geometry is the problem. I figured this out because I actually could solve it one time with Multiphase, but than the moving part moved so much, it hit the wall. So I changed the geometry. And with the very same settings it doesn't work anymore.
I attached a picture of both, the body which I can calculate without trouble to initialize (cube) and the body with which fluent shows the error as written above (cube_modified). Under the blue line is more or less where liquid is and above it is air. Any hints what could be wrong with my geometry? Thanks a lot in advance. Cube.PNG Cube_modified.PNG |
March 21, 2017, 08:27 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
2-Way FSI MultiPhase Simulation | Juli | ANSYS | 0 | March 17, 2017 04:52 |
multiphase simulation problem | Muhammadwaqas | CFX | 1 | April 24, 2014 03:48 |
Rigid body motion error when restarting a terminated FSI simulation | lingdeer | ANSYS | 1 | May 19, 2013 01:40 |
about valve closing problem during ANSYS FSI simulation | ivy | CFX | 4 | June 8, 2011 21:01 |
