Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
immiscible fluid flow, Courant number exceeds 250 after 0.18 seconds (flow time)
Old   March 20, 2017, 07:12
Default immiscible fluid flow, Courant number exceeds 250 after 0.18 seconds (flow time)
leo
leo2012 is on a distinguished road
Am trying to obtain the velocity profiles of the two immiscible fluids flowing through a 2D flat plate (height is 300 micrometer and width is 2 mm). The simulation condition - pressure based solver, Eulerian, transient, Realizable k- ε Model. Time step is 1e-6, no of iteration per time step is 20. I started the simulation with first order upwind and switched over to higher order schemes. The simulation was running fine until the flow time of 0.18 seconds then Courant number exceeds more than 250. Also the phases were well separated for half of the length of the channel but after that there are regions were the phase 1 is in the region of phase 2 near the walls and vice versa. (as shown in attached figure). Thanks in advance.
leo2012 is offline   Reply With Quote
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 14:52
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
