Masoud Ravan
Rep Power: 10 ![]() |
Hi everyone, I am simulating a hydraulic jump in the stilling basin. At the Beginning, flow starts from a rectangular channel. Fluent solved the problem but as you see in the pictures, there is a water surface reduction at the beginning...and I cannot find the reason
![]() ![]() ![]() ![]() ![]() inlet boundary condition for water: velocity inlet inlet boundary condition for air: Pressure inlet outlet boundary condition for air: Pressure outlet model: VOF, Implicit, transient Thanks in advance. ![]() ![]() ![]() ![]() |
fluent, multiphase flow, open channel flow, vof |
boundary conditions in FLUENT VOF for open channel flow | newcomer | Fluent Multiphase | 33 | May 28, 2024 13:41 |
Complex problem: Open Channel Flow | lett | FLUENT | 18 | November 10, 2018 18:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
Open Channel Flow | forsumit | FLUENT | 0 | October 1, 2009 02:01 |
