February 20, 2017, 15:45 |
VOF Grid Independence Test
Sajjan Pokhrel
Rep Power: 10 |
Hello Everyone,
I am simulating a newly developed cross-flow water turbine using VOF and MRF models (three dimensional). My concern is a power output from turbine. I calculated power which I believe is accurate output. Now I want to conduct Grid Independent Test in order to verify the result. I prepared seven different meshes to test, number of grid points ranging from 100,000 to 6,400,000 (100000,200000,400000,800000,1600000,3200000 and 6400000). I graphed instantaneous values of output power to compare the result. But what I found is, only three of seven graphs look alike. Other four (two with least number of grid points and two with most number of grid points) graphs look deviated. I have attached some of the graphs below. However, if I look contour of volume fraction of water for all cases, flow looks correct and promising. I it wise to accept the simulation and move forward with these results? |
git, moment, power, torque, vof |
Ansys fluent grid independence test | Jesh | FLUENT | 11 | February 4, 2020 09:54 |
vof grid independence and validation | vof_grid | FLUENT | 4 | March 19, 2007 13:40 |
Grid independence check | Mattis Voss | FLUENT | 1 | November 23, 2005 10:30 |
Grid independence check | Mattis Voss | FLUENT | 0 | November 23, 2005 07:31 |
Grid Independence problem for simple pipe geometry | chanchala | FLUENT | 13 | November 20, 2003 08:24 |
