Importing the .dat file in ANSYS WORKBENCH 17 |
January 26, 2017, 12:29 |
Mojtaba
Rep Power: 10 |
Hello there!
I am running a project in ANSYS WORKBENCH 17 - FLUENT.I put the parameter on Autosave each 10 time steps,and it works and the software produces some files every 10 time steps,the files are .RAR and when u extract them the file that comes out is not supported by ANSYS WORKBENCH,the name of the file for example is: FFF.1-8-00100.dat,I want import that in each 10 time steps and draw the contours for that time step.How can I do that?!Plz Help me!!!I'm in a hurry,thanks alot |
February 2, 2017, 18:33 |
Rep Power: 13 |
i guess just changing the name would work, remove to dot in the initial name for example rename it as xyz.dat and not x.yz.dat
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
