January 12, 2017, 01:30 |
Interaction between two discrete phases
Attaullah
Rep Power: 10 |
Hi every one,
I am wroking on simulation of ineraction of water droplets with dust particles. I have taken both the phases as discrete particles using DPM. I want to introuce the interaction between these two discrete phases. Is it possible to descriobe the interaction between these two discrete phases using DEM. When i turned on DEM model , fluent turn off the Breakup model . Can we use both and how. I am using Fluent version 17. |
November 26, 2020, 02:24 |
Dires Tazebew
i am trying to simulate an evaporative air cooler with anysys fuent, air is a primery phase which flows through porous material and water liquid is a secondary phase which flow over porous medium to cool incoming air in contour flow . but i have got the same temprature contour using sepecies transport with eulerian wall wilm. how can i set it?
Interaction between two phases | attaullah | Fluent Multiphase | 0 | January 2, 2017 12:41 |
Two discrete phases | why? | Fluent UDF and Scheme Programming | 1 | April 13, 2015 00:13 |
iteration questions in discrete phase | iknowjesus | FLUENT | 4 | March 13, 2015 07:07 |
multiphaseEulerFoam: PtrDictionary<phaseModel> phases_ of multiphasesystem fluid | maybee | OpenFOAM Programming & Development | 9 | January 27, 2014 07:24 |
Discrete event simulation vs. fixed time (discrete time simulation) | jenjon | FLUENT | 0 | March 10, 2013 07:58 |
