Heat transfer between droplets and heated wall in mist flow |
Bob
Rep Power: 9 ![]() |
Dear all,
I am doing a work to simulate mist flow within heated tube using Euler-Euler method. It is important to consider the heat transfer between droplets and heated wall. The Guo and Mishima model is used by writing UDF codes. My questions are: 1.Whether fluent contains this phenomenon if I choose the right turbulence model? 2. If I use UDF codes, whether all of the droplets will receive this energy source or only the droplets in the cells adjacent to the wall ? |
droplets, udf |
spray simulation with heat transfer using DPM | Tensian | Fluent Multiphase | 1 | June 7, 2016 04:57 |
