Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
particle trap visualization
Old   December 30, 2016, 04:41
Default particle trap visualization
akbar.mech is on a distinguished road
i simulate multiphase flow in fluent and i work on DPM. there is a problem i have searched a lot for it in the net and i have tested every option in fluent but found nothing. if anyone has any information about this, i would appreciate to share it:
how can we visualize the trapped particles on any of the domain walls. my model includes a bend and particles get trapped on the bend and the straight pipe after the bend. i want to see where the particles are trapped.
it is very important to me. i appreciate any answer.
akbar.mech is offline   Reply With Quote
Old   January 1, 2017, 13:08
any idea????!!!!!!!
Old   January 9, 2017, 19:18
hwet is on a distinguished road
if it is in steady state you can just go to particle tracks in the visualization options and track the particles. if it is unsteady you can write a particle data file and read it in cfd post to display the tracks. see the tutorials in the fluent tutorial guide, this should be covered as it is fairly basic and used a lot.
hwet is offline   Reply With Quote
Old   January 11, 2017, 16:26
actually i don't want the trajectories of particles. i only want to depict the trapped points of particles on the walls.
Old   February 2, 2017, 12:57
Default same problem
kaveh
kavehsh is on a distinguished road
actually I have the same problem and I didn't find the answer. but I think this problem don't have steady state part which means you should run the problem without particle then write this and activate the particle track. but I don't know how too find the location of particles
kavehsh is offline   Reply With Quote
Old   February 2, 2017, 18:28
If you guys want to visualize the particles actually stuck to the wall you might have to use the DEM
Old   February 3, 2017, 04:38
kaveh
why using DEM? actually what is different between DPM & DEM ?
Old   February 3, 2017, 11:13
thanks
but could you give more explanation? how can we do this using DEM ?
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 17:30
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Seed particle and trap it in a channel by CFX andox23 CFX 1 April 24, 2013 08:21
Seed particle and trap it in a channel by CFX andox23 Main CFD Forum 0 April 15, 2013 12:01
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
