Thin Film Condensation on Vertical Plate in Laminar Flow |
December 21, 2016, 15:18 |
Adrian
My name is Adrian and I am attempting to simulate thin film condensation on a vertical plate in a laminar flow. I am determining laminar flow by limiting my characteristic length to .1m and my input flow velocity to .01m/s. The Boundary condition for the cold side (heat sink) is set @ 100K, and opposite that I have an adiabatic wall. My velocity inlet is 100% steam @ 373.15K, and I have a pressure outlet as my opposing Boundary Condition. I am using Mixture model and am using Evaporation-Condensation model (Tsat=373.15K) for mass transfer, as well as surface tension to allow adhesion of condensate bubbles on the cold surface. I've attached a picture showing my results, and was curious if anyone had experience simulating this simple problem, and if so how by how many degrees I am off (figuratively). I appreciate the effort, as I have toiled for some time with this issue myself. ~Thanks |
May 19, 2017, 01:51 |
Diksha
Rep Power: 9 |
Hello Adrian,
I am also working on condensation, however in a vertical tube and it is turbulent. I am using VOF model and Lee model (the evaporation-condensation model). My simulation keeps on diverging. I have tried all possible URFs. Checked my mesh. Still, it diverges. Do you have an idea why it does that? Any help/advice from you will be greatly appreciated. Stuck on that for a while. Thanks |
evap-condense model |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 05:42 |
High velocity in Laminar flow | Manojmech | FLUENT | 0 | November 3, 2016 05:37 |
Natural convection flow over hot vertical plate | M.sridhar | FLUENT | 8 | June 6, 2011 09:46 |
laminar flow on flat plate | AmirFluid | Main CFD Forum | 7 | June 22, 2010 06:49 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
