December 17, 2016, 17:17 |
boiling heat transfer
Abdalqader Ahmad
Rep Power: 11 |
Hi
I have a case where the flow passes through an extremely hot pipe, and by the time the pipe is cooled by the fluid until it reaches the fluid temperature. There is no heat applied on the pipe's surface. In this case three different types of boiling are expected: film boiling, transition boiling and nucleate boiling and I need to model this case by modifying the the below UDF that provides in the Ansys UDF manual. This UDF calculates the Nu and heat transfer coefficient (h) for the nucleate boiling. I need to add If statements to this UDF which allow me to add the other two boiling types. Boiling types depend on the temperature difference between the wall pipe (Tw) and the fluid domain (Tf) where: if Tw-Tf<30 then nucleate boiling occur if 30<Tw-Tf<120 then transition boiling occur if Tw-Tf>120 then film boiling occur I already have the Nu and h of each boiling type I there and one can help me to modify this UDF or have any other solution. #include "udf.h" #define PR_NUMBER(cp,mu,k) ((cp)*(mu)/(k)) #define IP_HEAT_COEFF(vof,k,nu,d) ((vof)*6.*(k)*(Nu)/(d)/(d)) static real heat_ranz_marshall(cell_t c, Thread *ti, Thread *tj) { real h; real d = C_PHASE_DIAMETER(c,tj); real k = C_K_L(c,ti); real NV_VEC(v), vel, Re, Pr, Nu; NV_DD(v,=,C_U(c,tj),C_V(c,tj),C_W(c,tj),-,C_U(c,ti),C_V(c,ti),C_W(c,ti)); vel = NV_MAG(v); Re = RE_NUMBER(C_R(c,ti),vel,d,C_MU_L(c,ti)); Pr = PR_NUMBER (C_CP(c,ti),C_MU_L(c,ti),k); Nu = 2. + 0.6*sqrt(Re)*pow(Pr,1./3.); [/COLOR][/COLOR][/COLOR]h = IP_HEAT_COEFF(C_VOF(c,tj),k,Nu,d); return h; } DEFINE_EXCHANGE_PROPERTY(heat_udf, c, t, i, j) { Thread *ti = THREAD_SUB_THREAD(t,i); Thread *tj = THREAD_SUB_THREAD(t,j); real val; val = heat_ranz_marshall(c,ti, tj); return val; } |
boiling modeling udf |
Radiation heat transfer boundary condition | natrask | OpenFOAM Programming & Development | 0 | February 8, 2015 10:05 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 18, 2014 00:45 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
